25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009 Wall Base Extension
10 Posts No Rating |
Wall base extensions were easy in Revit 2008 -- just edit the wall properties in section view and unlock each piece of the sandwich. They've changed the process in 2009 -- there's no padlock to click when I select a sandwich piece. How does it work now? Thanks so much for your help! - eye
I didn't see any difference in this function. Make sure you are clicking the Modify button in the section properties.
Agreed there is no difference with this functionality in 2009.
Regards,
Chris.
Base Extension Distance + Wall Sweep (at base) |
Wed, Jun 3, 2015 at 6:26:49 PM
Wall Base Offset... one works, one doesn't. Why? |
Wed, Jun 10, 2015 at 2:53:52 PM
Wall Joins Disappear When Base Extension Distance Parameter Not Zero |
Wed, Oct 12, 2016 at 3:26:45 PM
Wall Footing on Walls w/ Modified Base Extension |
Thu, Nov 21, 2013 at 12:06:48 PM
Railing without extension |
Fri, Oct 2, 2009 at 10:54:50 AM
