21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Settings - Project Information help
4 Posts No Rating |
Could someone help me please. At my country we have to put into the titleblock of the sheet more information than revit let you introduce at the project information. Is there a way to customize that information so let you have more fields to fill in the project information or there is another way to make it? I am using Revit 6.1.
Post edited on 2005-03-29 11:50:25
Yes.
When you click label, instead of picking from the list of fields click add...
You'll need to create a shared parameter file for the new fields.
Check out the help on shared parameters and titleblocks in revit.
If you still are having trouble i'll try to give a more step by step direction when i get some free time...
4 Posts No Rating |
Thak you a lot Mr. Spot, and sorry for replay to late, i could not connect to the internet for a while. I use your advise and it works but there are some parameters that are global at project level and i wish to introduce just one time. Likewise there are some parameters that i wish the field to behave like others predefined fields in wish i can choose from a list, like a combo box or something like that.
Thank you a lot for your help. I am just learning revit and there are many things to learn.
40 Posts No Rating |
If you want the shared parameter to be global at project level then assign the parameter to project information category in here you can input the value once and it will show up to all your sheets. If you want the parameter to appear differently for each sheet then assign the parameter to drawing sheets category.
4 Posts No Rating |
Thank you very much for your answer Arnel Aguel but I don't know how to do it. I mean how can I assign the parameter to project information category? please, i'll apreciate it a lot. I am just learning how to use revit.
Once you have created your shared parameters in the titleblock family editor then save it. In your project load your shared parameters from the settings menu bar by clicking project parameters then click add and it will open up parameter properties then select shared parameter click select button then navigate to your shared parameters then select one by one and associate it to project information category if you want it to be project wide value or select drawing sheets category if you want it to be by sheet value. Finally load your titleblock in your project then input the necessary values.
Hope it is clear now.
Post edited on 2005-04-17 00:24:48
4 Posts No Rating |
Thank you very much, i tried and it works perfectly, thank you.
Glad i'm able to help and that is what this community is all about.
New Title Page Label Using Project Information |
Sat, Feb 10, 2018 at 11:54:48 AM
"Project Information" frozen |
Wed, Oct 17, 2012 at 3:56:29 PM
project information |
Thu, Feb 24, 2011 at 1:48:15 PM
Project Information Parameters |
Tue, Jul 27, 2010 at 5:31:45 PM
Scheduling Project Information |
Tue, Sep 25, 2007 at 11:43:03 AM
