Forums >> Revit Building >> Technical Support >> Removing Wall Sweep or Reveal
Fri, May 2, 2008 at 10:51:51 AM | Removing Wall Sweep or Reveal
JLudwig
I am using Revit 2008
How do you delete a Wall Sweep or Reveal from a wall?
Fri, May 2, 2008 at 12:00:28 PM | Removing Wall Sweep or Reveal
mhans
3 Stars: 10 Votes
Hi,
Is this a trick question? Select the reveal or the sweep (zoom closer if a bit crowded) then hit the "del" button. You might want to use the "Tab" button to cycle through your selection, if say you pick something else next to it. Once the reveal/sweep highlights, hit "Del". That should do it!
Thanks,
Mhans
Motto: "No Post left behind"
Fri, May 2, 2008 at 12:10:35 PM | Removing Wall Sweep or Reveal
JLudwig
Not a trick question. I tried that and all it does is delete the whole wall.
Fri, May 2, 2008 at 12:25:50 PM | Removing Wall Sweep or Reveal
You deleted the whole wall because that is what you selected.  If you are having trouble selecting the sweep, cross it then use your filter to only select the reveal or sweep.
Fri, May 2, 2008 at 1:29:54 PM | Removing Wall Sweep or Reveal
mhans
3 Stars: 10 Votes
Hi,
It's weird. One thing to find out. Can you pick the wall? Does the tool tip say, Walls and its property? If yes, do as instructed previously. If not, is it a Created solid? If yes, edit the profile. If it's a wall and still you can't remove the reveal/sweep, can you re-create the wall? If not, what are the warnings/errors you're getting?
Thanks,
Mhans
Fri, May 2, 2008 at 1:39:03 PM | Removing Wall Sweep or Reveal
jbaysinger
3 Stars: 4 Votes
Your reveal or sweep might be built directly in the wall.  Click on the wall, go to properties, edit/new, edit.  Now click preview on the bottom and then drop the view(on the bottom left) down to section.  Now you can click on reveals and sweeps and delete them from your wall in here.  You will be able to see them in the section view if they are there.  Don't know if that helped or not?  If I understood what was going on.
Fri, May 2, 2008 at 2:40:56 PM | Removing Wall Sweep or Reveal
JLudwig
Thanks jbaysinger - That was exactly it.
Thu, Apr 17, 2014 at 2:46:46 PM | Removing Wall Sweep or Reveal
warrenarch
there is some good advice here. editting the wall properties works (under some circumstances), but I found that it does not work if you manually dropped the reveal on the wall face. What worked for me is cutting a section, then zoominng in on that view and selecting the reveal in my section and deleting it from there.
Reveals/Sweeps is really powerful! Check out the automated way to create them under the "edit type" > "edit sturture" > "modify vertical structure"....for example, you can literally create every raked masonry joint in the wall this way by duplicating and assigning heights....
Wall Sweep - Reveal; How to dimension to reveal centerline? (RAC 2009)
Wed, Apr 14, 2010 at 2:35:31 PM
Solid/Void for Reveal/Sweep/Mullion
Wed, Jun 3, 2009 at 2:15:11 PM
Combining Wall reveal and sweep
Wed, Jun 11, 2008 at 12:40:05 PM
how to add a self made reveal to a wall while edit wall types?
Sat, Feb 12, 2011 at 10:53:31 PM
Bevel Siding
Sun, Apr 3, 2016 at 10:46:42 AM
Page generation time: 1.0104
