12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Can Railings show in Ceiling Plans?
7 Posts No Rating |
I'm in Revit arch 08 I've modeled an mep bulkhead element as a railing, which worked well. Now I'm having a hard time seeing it in Ceiling Plans. I have all railings (everything actually) turned on in VG and the View Depth is up to the Next Floor, the cut level is 4'6", below the bulkhead. Any ideas?
Hi, You need to adjust your View Range-Cut plane. Go to View Properties-View Range-Cut Plane-Offset.The Cut plane offset should be cutting the height of your rails. Some other objects, though might show that lie on the same level. If you don't want to do that and your bulkhead is not that many, you can mimic the bulkhead with a detail line, if it's not a pain. Thanks, Mhans
Motto: "No Post left behind" |
11 Posts No Rating |
I am having the same problem, but I'm afraid that solution didn't work for me. Is there something in the railing family itself that blocks the view? I am new to this but I don't see a way to edit Revit's Basic railing family...I want to check to see if it's turned off in certain views, etc.
Floor Plans need to show Ceiling on them in Revit 2011 |
Thu, Aug 26, 2010 at 12:40:35 PM
Room Tags on Ceiling Plans |
Fri, Mar 4, 2005 at 9:36:28 AM
Reflected Ceiling Plans not showing in Electrical Plans |
Wed, May 4, 2011 at 1:19:05 PM
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting |
Tue, Sep 13, 2011 at 11:12:09 AM
Lighting without ceiling |
Thu, Sep 10, 2009 at 11:02:50 AM
