Forums >> Revit Building >> Technical Support >> AutoCAD details
Thu, May 1, 2008 at 8:24:14 PM | AutoCAD details
rgaaia
Can anyone tell me if it is possible to use AutoCad detail libraries in Revit???............ they are two-dimensional detail with keynotes already labeled..... can they be brought in as a sheet separately and added to a REVIT drawing sheet???
Thu, May 1, 2008 at 11:12:21 PM | AutoCAD details
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Although I would suggest you eventually convert all your legacy ACAD details to Revit Detail Components or Detail Groups, it is definitely possible to make use of them.
 Just import them into a new revit drafting View and then drag it on a sheet...
Regards,
Chris.
Autocad details linked into Revit
Mon, Jun 6, 2016 at 1:54:23 PM
Autocad details with hatch showing as black/solid
Wed, May 22, 2013 at 11:47:29 AM
LInked AutoCAD details into Revit 2009 workset project
Tue, Jun 28, 2011 at 5:07:32 PM
Autocad details to Revit
Thu, Nov 3, 2005 at 6:25:49 PM
Importing Autocad to Revit, adding details and notes, then back out to Autocad
Thu, Feb 18, 2010 at 8:57:44 PM
Page generation time: 1.8570
