Forums >> Revit Building >> Technical Support >> rotating elements in section view
Thu, May 1, 2008 at 7:19:40 PM | rotating elements in section view
sisco
I'm using MEP '08 and every time I rotate something in a section view it sends it out hundreds of feet somewhere else. Sometimes I find it and sometimes I don't. Why does it do this and how do I fix it?
Thu, May 1, 2008 at 11:24:27 PM | rotating elements in section view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'm unsure if you'll get much support in here for MEP as its still pretty early in its development.  I haven't actually used it, but the first thing I'd check would be the origin point of the family and extents.  See what reference planes are defining origin and make sure they are constrain to the reference level.
Alternative check out AUGI as you may find some more MEP users there.
HTH.
Regards,
Chris.
Method to Align Section view to modeled elements
Wed, Nov 30, 2016 at 1:06:51 PM
Rotating 3D Elements all at once
Thu, Dec 8, 2016 at 6:51:20 PM
12
Rotating W-Shape Frame relative to section
Tue, Aug 23, 2011 at 6:03:12 PM
Rotating Crop Regions & Vanishing Section Markers
Fri, May 14, 2010 at 10:24:58 AM
DIFFERENT LINE THICKNESSES FOR STRUCTURAL FRAMING ELEMENTS IN SECTION
Tue, Sep 28, 2010 at 7:16:14 AM
Page generation time: 0.8268
