Forums >> Revit Building >> Technical Support >> Sloped landings in stairs
Thu, May 1, 2008 at 6:25:18 PM | Sloped landings in stairs
Underdawg
Revit 2008
Does anyone know if its possible to model a sloped landing with the stair tool?
Right now the only way I achieved this was create one run, then place a ramp in between, basically breaking up the stair into several different objects.
The problem I'm running into is with the railing. Since it's all broken up, it simply won;t create a nice continuous railing, also the 42" aren't kept everywhere. Is there anything else I can host a railing with besides floor slabs and stairs?
Assembled Stairs - Joining stringers from one set to the landings of another
Thu, Mar 13, 2014 at 3:13:48 AM
Stairs and Landings
Mon, Aug 3, 2009 at 6:50:57 PM
3 run stair case w/ 2 landings
Tue, Apr 3, 2012 at 2:44:18 PM
13
Revit Architecture 2008 Multi Level Stairs - Complex Building
Sun, Dec 4, 2011 at 4:39:37 AM
Help with stairs
Fri, May 4, 2018 at 7:32:59 AM
Page generation time: 0.1030
