Forums >> Revit Building >> Technical Support >> Missing Louvers in 3D view? rac 2009
Thu, May 1, 2008 at 9:28:32 AM | Missing Louvers in 3D view? rac 2009
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Hi to all.My visibility graphic affect my louvers in 3d, I can't find how to override this, thanks
Mon, May 5, 2008 at 7:32:15 AM | Missing Louvers in 3D view? rac 2009
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
I surrender with this one, I can't find the solution Sad
Mon, May 5, 2008 at 8:15:35 AM | Missing Louvers in 3D view? rac 2009
There is no way to determine what the visibility settings control from looking at your post.   Perhaps, if you posted your louver family, someone could help.
Tue, May 6, 2008 at 7:41:25 AM | Missing Louvers in 3D view? rac 2009
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Sorry for delay, rush in work.
Here the exibit "A"!
guilty!
 I create the louvers as generic model and convert using "Family Category and Parameters" to window family.
Any Ideas?
Thanks
Tue, May 6, 2008 at 10:14:55 AM | Missing Louvers in 3D view? rac 2009
Someone with 2009 will have to look at this.  Our office is supposed to load in this week.
Tue, May 6, 2008 at 12:24:04 PM | Missing Louvers in 3D view? rac 2009
PeteGGA
Your 3D view must be on course setting, the object that is not showing will show in medium and fine, change the 3d view setting to fine, other than that i cant see anything else that would fix it
Pete
Tue, May 6, 2008 at 12:29:00 PM | Missing Louvers in 3D view? rac 2009
PeteGGA
Sorry, i found the problem, the bars are a hosted family, if you select the bar in the family and edit the bar family, you'll see the visibility is turned off for course
 Pete
Tue, May 6, 2008 at 2:37:26 PM | Missing Louvers in 3D view? rac 2009
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Yes. but if a section plane split my windows in a 1/8"=1-0" scale, I need the louvers off.
 you know a clean window, so I need to clear the coarse box.
So the only solution is to play with the detail level in the views that i need the louvers.
Sun, Oct 15, 2017 at 10:17:13 AM | Missing Louvers in 3D view? rac 2009
seychellian
Hi would you be so kind as to send me this family? I cant find a good glass louver family anywhere.
Thanks
Mon, Oct 16, 2017 at 6:28:53 AM | Missing Louvers in 3D view? rac 2009
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Just download the rfa louvre family that was attached in the previous thread message. Open it in Revit. Select a louvre group, edit the group. Select the louvre blade itself and click edit louvre blade family. Open that louvre blade family, select each 3d object within that family and under visibility tick the display when coarse option. Save louvre blade family back into louvre family. save group. reimport back into model.
RAC 2009 Slow Down - Possible Fix
Sun, Jun 15, 2008 at 8:20:42 AM
Glass louvers/ brise soleil
Mon, May 25, 2015 at 12:18:27 AM
Modifying a curtain panel system to add louvers
Thu, May 22, 2014 at 2:53:35 PM
RAC 2009 - Linked CAD file in Ceiling Plan View
Wed, Jul 15, 2009 at 12:53:08 PM
Louvers in door not appearing correctly in 3d or section views
Thu, Feb 8, 2007 at 8:31:15 AM
Page generation time: 2.3354
