21 Users Online (20 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> constrained levels
Thu, May 1, 2008 at 7:24:36 AM | constrained levels
Sparky
5 Stars: 3 Votes
OK, I constrained levels to be equal (when I created them) and very stupidly didnt remove the constraint before deleting the view! Well at least thats what I think I did.
The result is that I cant change the levels without all of em changing. Please tell me there is a way of unconstraining them!
Im using Revit 2008
Thx for the help.
Thu, May 1, 2008 at 8:18:45 AM | constrained levels
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Select one of the Levels and check across the whole view. You should still see the EQ constraint even though the dimension is there. It usually is not in the same location as the dimension.
Thu, May 1, 2008 at 8:26:59 AM | constrained levels
You can also add new constraints to over-ride the old ones.  I often add a new set of dimesions, lock the ones I don't want to move then move the one that I do want to move.
Level trouble - Level Constraints
Tue, Jul 13, 2010 at 9:44:54 AM
Objects constrained to level ...
Wed, Feb 3, 2010 at 6:28:25 PM
Element constraints - Revit Structure 2008
Fri, Aug 3, 2007 at 3:08:58 AM
Changing model constraints from one level to another
Wed, Aug 12, 2015 at 3:07:56 PM
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Page generation time: 3.3060
