13 Users Online (12 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Whole circle bearing
Wed, Apr 30, 2008 at 9:06:38 AM | Whole circle bearing
aimeed
Does anyone know how you can take angles beyond 180 degrees, is there a setting that you can change which will allow to take angles beyond 180 degrees? I am trying to do whole circle bearings and can only get to 180 degrees from the start line the rest I have to work out manually..... Can anyone help???!
having trouble with bearing and distances
Mon, Jun 9, 2014 at 9:22:36 PM
Bearing vs. Non-bearing walls
Wed, Oct 10, 2012 at 3:04:30 PM
Property Arcs - Input Delta Bearing
Mon, Mar 13, 2017 at 3:28:26 PM
Mass Geometry Flaw | Circle points
Fri, Dec 4, 2015 at 4:04:46 PM
Changing a non-bearing wall to a bearing wall
Fri, May 4, 2007 at 2:13:57 PM
Page generation time: 0.0429
