Forums >> Revit Structure >> Technical Support >> Import DGN files
Tue, Apr 29, 2008 at 2:09:42 PM | Import DGN files
chaggas
Is it possible to import a .dgn file into Revit and pull information such as column and beam sizes out of it?
I am under the impression that when importing a 3D block I am doing just that, importing a 3D image. If I import it as a mass I should be able to use the pick face command and assign materials to it, but as far as pulling information from it, it seems as though that is only possible between two Revit applications. Does anyone have experience importing .dgn files? Does anyone know how I could read information from this .dgn file through Revit or AutoCAD?
FYI, I don’t have MircoStation.
Thank you,
Cynthia
Wed, Apr 30, 2008 at 2:58:19 AM | Import DGN files
phildixon
1 Stars: 1 Votes
I'm not sure but I think you would need to export a .sat file from Microstation and import the .sat file into Revit which would then give you 3D solids. Maybe!
DGN links in Revit MEP 2009
Wed, Mar 11, 2009 at 9:00:00 AM
COnverting Revit to Bentley Bim
Wed, Jul 8, 2009 at 10:12:53 AM
Turning off imported microstation dgn layers in Revit model
Tue, Nov 10, 2009 at 1:21:02 PM
dwg 3D blocks
Wed, Dec 3, 2003 at 6:37:53 PM
HOW TO IMPORT 3DS files and DXF files into REVIT 2011?
Sun, Nov 7, 2010 at 6:21:00 PM
Page generation time: 7.9499
