14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Change Leader line weight
Hello there, simple question, how do I change the line weight in my leaders? If I go to arrowheads in settings>>annotations... then the option to change the line weight is greyed out. thanks, lorne
Denver, CO
Revit Architecture |
For text objects you have to select a piece of text and go to Properties-->Edit/New. You can change the lineweight there. For tags and symbols the lineweight is controled in the Object Styles box under the category for each tag type.
Heavy Weight Leader Arrows |
Fri, Jan 20, 2017 at 3:33:11 PM
Impossible to change ceiling pattern line weight |
Tue, Jan 22, 2013 at 11:03:23 AM
change line weight in a family |
Sat, Jul 3, 2010 at 5:12:25 PM
Line Type Weight Will Not Change, Overrides Set Will Not Show [ 1 2 ] |
Sun, Dec 13, 2020 at 11:51:32 AM
16
Dimension Line Weight |
Fri, Oct 7, 2016 at 1:32:52 PM
