18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Mitering Sloped Floors?
How to miter a sloped floor with a horizontal floor?
I assume you are on RAC2008...... Draw the outline of the whole floor and use the floor slope tool. If you don;t know what that is, draw the outline of the floor (including the sloped area) so it is all one hieght, click finish. Then left click on the floor and you will get some editing options for the floor. Help menu can explain further. If you are trying to accomplish something else, you can join the floors together using the join command.
Just reiterating what Lizard said. Do it all as one floor and use the point edit tool to do the slope section rather than a slope arrow.
Regards,
Chris.
Thanks, Lizard, Chris I asked the question because just mitering with the join tool and trim to a continuous thickness is unproportionally complex... Using the editing tool to aggegate the two slabs in one is the way to go. Thanks for taking time to provide this basic still very useful tip. Ricardo
20 Posts No Rating |
After you add a point for a slope, is there a way to undo that point, without having to start all over by resetting shape?
If I am understanding the question, it is quite simple. Click on the Select and Modify button on the options bar, right click on the point you want to delete and there is an option in the pop up menu to delete it.
thanks!!!!
detail lines on sloped floors |
Tue, Jan 24, 2012 at 4:00:04 PM
14
Sloped railing on a Floor |
Fri, Jul 2, 2010 at 11:32:10 AM
sloped floors |
Thu, Jan 27, 2011 at 11:52:11 AM
Mitering curtain wall panels |
Wed, Dec 26, 2007 at 9:11:55 AM
mitering gutters |
Tue, May 2, 2006 at 8:59:03 AM
