Forums >> General Discussion >> Wishlist >> Steel in Revit 8 - trimming steel shapes
Mon, Mar 28, 2005 at 8:57:47 PM | Steel in Revit 8 - trimming steel shapes
softfirm
it would be nice to have the ability to edit steel joins in a similiar way that we can trim walls together. ex. i have 2 channels meeting in a V shape. Currently there appears to be no way to have these 2 pieces miter.
Fri, Oct 7, 2005 at 3:41:23 PM | RE: Steel in Revit 8 - trimming steel shapes
quiller
quiller Avatar
2.5 Stars: 3 Votes
If you create your steel as a wall type perhaps it will work.
Fri, Oct 7, 2005 at 5:13:13 PM | RE: Steel in Revit 8 - trimming steel shapes
karok
you can do this now. you just need to overlap the steel (not much, just a little), then draw a ref plane, and use the cut geometry command. see the attached file
If you have any questions or comments please feel free to contact me. Jason Chamberlain Senler, Campbell and Associates, Inc. jason@senlercampbell.com
Fri, Oct 7, 2005 at 11:47:56 PM | RE: Steel in Revit 8 - trimming steel shapes
Steve_Stafford
5 Stars: 2 Votes
Sorry that feature is limited to Revit Structure, we can't do that in Revit Building yet!
Fri, Jul 6, 2007 at 11:47:23 AM | Steel in Revit 8 - trimming steel shapes
rsampat
is there any way to trim steel in revit 9??
MC Steel shapes
Thu, Apr 26, 2018 at 3:34:33 AM
sloped steel?
Thu, Apr 8, 2010 at 5:51:25 PM
revit steel questions
Mon, Apr 6, 2015 at 9:27:20 AM
Make a grate w/ standard steel shapes
Tue, Sep 4, 2007 at 12:11:13 AM
Modifying stairs to use custom steel stair pan
Fri, May 16, 2008 at 1:01:00 AM
Page generation time: 3.2359
