Forums >> Revit Building >> Technical Support >> coarse scale fill pattern
Tue, Apr 29, 2008 at 8:17:50 AM | coarse scale fill pattern
hippy
We are using different colored coarse scale fill patterns to differentiate between wall types. I have a series of 5'0" walls in this building and no mater how I set the view range I cannot get the fill to show up. Any hints?
Tue, Apr 29, 2008 at 8:23:48 AM | coarse scale fill pattern
REVIT has a problem with short walls and this has been discussed before but I don't remember what key words to use to look for the thread.  Believe it or not, set you cut plane to cut your wall then play with your view range and depth until your wall appears correctly.
Tue, Apr 29, 2008 at 8:48:54 PM | coarse scale fill pattern
twometer
3 Stars: 2 Votes
Thought I could see if I could Replicate the problem and I did.  Here is my solution...  for some reason is it because the wall is unconnected in height.   Change the top constraint to the level you are working on and add a top offset of 5'-0".  This should solve your problem.
 Let me know if this works...
Revit 2013 text in coarse scale fill patterns
Mon, Feb 11, 2013 at 7:27:59 AM
Existing Walls with Coarse Fill Pattern Revit 2008
Wed, Aug 13, 2008 at 3:28:01 PM
Topo coarse scale fill color
Fri, Jun 15, 2007 at 10:00:13 AM
MEDIUM SCALE FILL COLOR AND PATTERN
Tue, Sep 11, 2012 at 7:06:12 AM
How to add 'Coarse Scale Fill' parameter to family
Thu, Dec 15, 2005 at 2:49:21 AM
Page generation time: 1.0029
