Forums >> Revit Building >> Technical Support >> EXCISTING BUILDING FILE AND NEW BUILDING FILE, HOW TO MERGE P.E. ELEVATIONS?
Tue, Apr 29, 2008 at 7:48:07 AM | EXCISTING BUILDING FILE AND NEW BUILDING FILE, HOW TO MERGE P.E. ELEVATIONS?
elvis
hI ALL,
I have an excisting model and a new building model, but in the new building model I created sheets, how could I implement an elevation form the excisiting model [drawing sheet] into the new building model!
somehow revit doesn't allow sheets with elevations based on a model!!
is there  a way?
i tried to export the elevation as a file, but it wont be merged on a drawing sheet
Tue, Apr 29, 2008 at 7:51:59 AM | EXCISTING BUILDING FILE AND NEW BUILDING FILE, HOW TO MERGE P.E. ELEVATIONS?
elvis
revit says, it cannot merge drawing sheets or view based on model views??
 is there a way to convert this view to a impartable, mergeable format, like only 2d elements?
Tue, Apr 29, 2008 at 7:54:05 AM | EXCISTING BUILDING FILE AND NEW BUILDING FILE, HOW TO MERGE P.E. ELEVATIONS?
elvis
Ok yes,
create an image from the excisting elevation and insert that in the drawing sheet? is this the way??
Moving a building into another file
Mon, May 7, 2018 at 8:29:26 AM
need an exterior view of the building in a DXF file.
Mon, Apr 23, 2012 at 9:12:38 AM
Managing sheets and links
Fri, Feb 6, 2009 at 7:03:06 PM
One File or Linked Files
Wed, Apr 20, 2011 at 6:35:11 AM
Building Levels Vs Grade Levels
Fri, Jan 14, 2011 at 10:32:00 AM
Page generation time: 7.2439
