29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Room behavior different in 2009
I can't seem to get the color scheme legend to behave the same as the previous version. Specifically, i used to overlay two rooms in order to get a solid fill and a crosshatch to display together. In the current release, it's either one or the other and the primary blocks the other from showing. Is there some setting that will allow some transparency to the crosshatch that will allow the solid fill to show through?
i am assuming the hatch is a filled region. just right click go to override graphics in view, select element and check transparancy. this should do the trick. you may have to override it in vg, if you want all filled regions to behave like this. hth
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/ |
Walls Behavior ???? |
Wed, Feb 25, 2009 at 11:09:00 AM
13
box around room number on room tags |
Sun, Dec 13, 2020 at 9:59:00 AM
Quantities By Room |
Mon, Dec 29, 2008 at 11:07:32 AM
2009 ROOM BOUNDING - non enclosed errors |
Thu, Jul 24, 2008 at 9:28:34 PM
editing room boundaries [ 1 2 ] |
Thu, Oct 5, 2017 at 7:21:19 AM
17
