Forums >> Revit Building >> Technical Support >> Render with no Shadows
Mon, Apr 28, 2008 at 1:32:25 PM | Render with no Shadows
mystikala111
Trying to render from a camera in Revit Architecture 2008 without having any shadows in the rendering. The only light source being used is the sun. Is this possible? If so any help would be greatly appreciated! Thanks.Sean
Mon, Apr 28, 2008 at 1:37:50 PM | Render with no Shadows
4 Stars: 205 Votes
In Render setting you can control the Sun and Shadows, try the help menu about this...
Mon, Apr 28, 2008 at 1:43:46 PM | Render with no Shadows
mystikala111
I believe you are referring to the settings menu within the rendering tab? Inside there are settings such as interior or exterior, environment, lighting, and sun. I have looked all through these menus and have found nothing about turning off shadows for rendering. If you know the steps could you lead the way please?
Mon, Apr 28, 2008 at 1:46:48 PM | Render with no Shadows
4 Stars: 205 Votes
Yes, is the settings menu in the rendering tab, or write SU and you enter in SUN and Shadows menu...
Mon, Apr 28, 2008 at 1:56:05 PM | Render with no Shadows
mystikala111
So I am looking at the same menu... there are no options for turning off shadows.
Edited on: Mon, Apr 28, 2008 at 1:56:35 PM
Mon, Apr 28, 2008 at 2:13:00 PM | Render with no Shadows
4 Stars: 205 Votes
Look, go to Render scene settings then click in "SUN" and after click in "Settings", here you have "SOFT SHADOWS" with "softness" "Jitter" and "Samples", try this...
Mon, Apr 28, 2008 at 2:34:35 PM | Render with no Shadows
mystikala111
Alright thanks! I will try those options and report on what I find. I appreciate your help, I realize its a pain since my knowledge of the program is so limited.
Mon, Apr 28, 2008 at 2:38:04 PM | Render with no Shadows
4 Stars: 205 Votes
You welcome... try the help menu when you are in SOFT SHADOWS...
Render Shadows
Wed, Mar 19, 2008 at 8:41:31 AM
Getting rid of shadows in Revit rendering?
Sun, Dec 3, 2017 at 2:06:46 AM
shadows
Mon, Apr 18, 2005 at 2:55:11 AM
Taking Shadows off in interior renderings? Possible?
Sat, May 1, 2010 at 1:44:12 PM
Strange shadows on render (imported CAD blocks)
Mon, May 21, 2012 at 8:29:21 AM
Page generation time: 0.7615
