Forums >> Revit Building >> Technical Support >> Piers/Pilaster joins
Mon, Apr 28, 2008 at 8:50:54 AM | Piers/Pilaster joins
TEC1
1 Stars: 1 Votes
I can't seem to figure out why my pilaster wall joins are not graphically correct.  If I draw a structural wall and drop in a pilaster at the same elevation it shows the (2) elemants overlapping until I use join at which point the lines from the wall intersecting the pilaster are trimmed.  But then I drop the pilaster elevation some inches below the top of wall elevation and then foundation wall lines re-appear going thru the pilaster.  How can I get these to look correct as explained in previous example.
 Thanks
Concrete Pilaster at wall intersection
Tue, Sep 28, 2010 at 11:16:08 AM
Pilaster
Sat, Jun 30, 2007 at 10:15:22 AM
Pilasters
Mon, Jul 2, 2007 at 11:14:39 AM
foundation piers
Mon, Feb 18, 2008 at 5:36:11 PM
Brick Piers
Fri, Jul 8, 2011 at 3:14:27 PM
Page generation time: 1.7070
