Forums >> Revit Building >> Technical Support >> Roof ridge revit 2009
Mon, Apr 28, 2008 at 6:16:14 AM | Roof ridge revit 2009
nirim
5 Stars: 12 Votes
Das anyone know why the method of inserting ridge tiles on the roof using Host Sweep ---- Roof Fascia das not seems to be work with Revit 2009 were it worked like a treat in 2008 version
nirim
Thu, Jul 31, 2008 at 7:28:30 AM | Roof ridge revit 2009
cpbc
3.5 Stars: 3 Votes
I am having the same problem here. I am trying to model the ridge tile and hip tile on roof and realise that the Host Sweep on Roof Facsia do not allow you pick on the ridge or hip anymore in Revit 2009. Any reason why they take out the function from Revit 2009? Is anyone out there able to give a work around? Thanks.
Thu, Jul 31, 2008 at 9:29:11 AM | Roof ridge revit 2009
4 Stars: 205 Votes
What are you talking about? i create my profiles "Fascia" and can with "Host Sweep-Roof Fascia" put the profiles in the ridge of roof....
Can you put some screen shot what do you try to do?
Thu, Jul 31, 2008 at 10:49:15 AM | Roof ridge revit 2009
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You cannot use the Host Sweep Roof Fascia in 2009 to do anything other than the 'fascia' edge of a roof. Before 2009 you could pick any edge of the roof including ridges, hips and valleys. That capability is simply gone for 2009.
The best way to acomplish modeling a ridge tile is to create a generic line based family. Then sketch or nest the profile family within that line based family. Then you can place your ridge and rake tiles anyware on the roof.
I have a brand new series of videos just released that covers this exact topic + lots more. It is called the Santa Barbara House Kit and can be located here > http://www.cadclips.com/REVIT-AC-2009-SantaBarbaraHouseKit.aspx
Also see images attached on the resulting line based tile family you can build yourself.
Thu, Jul 31, 2008 at 11:07:20 AM | Roof ridge revit 2009
4 Stars: 205 Votes
Hi, see this: http://www.marathondrafting.com/?p=74
and this:http://www.megaupload.com/pt/?d=W45S8N6R and go to this post:http://www.revitcity.com/forums.php?action=viewthread&thread_id=1862  and download the "41511-Telho.rfa" and the others *.rfa on that post, take a look of that post, are in portuguese but you can see the images and some URL of videos made by Cesarita with this kind of roofs, it's very simple....
Edited on: Thu, Jul 31, 2008 at 11:10:34 AM
Fri, Aug 1, 2008 at 3:12:55 AM | Roof ridge revit 2009
nirim
5 Stars: 12 Votes
Autodesk release up-to-date patch pack for REVIT 2009 Architectures Suite and that solve the problem of inserting ridge tiles in the same manner as it worked in the previous REVIT versions i.e. you use the roof fascia tool and   pick the ridge line.
  NIRIM
Fri, Aug 1, 2008 at 10:18:06 AM | Roof ridge revit 2009
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Thanks, Nirim, I just updated my RAC to Build 20080602_1900 and you are correct. It's not a Hotfix or Service Pack / Patch it's just in the latest build. The Host Sweep > Roof Fascia now works on roof ridges again. Yeah ! So all you need is the clay tile profile and you're off and running. Thanks for the tip.
Fri, Aug 1, 2008 at 11:07:45 AM | Roof ridge revit 2009
nirim
5 Stars: 12 Votes
dgcad I am not sure about what exactly you install however although the ridge is no longer a problem, the render is i.e. the render material library vanished from the software.     Is it you from the dgcad video clips? If the answer is yes then I use the opportunity to thanks you, I would say they are grate.
nirim
Fri, Aug 1, 2008 at 3:30:32 PM | Roof ridge revit 2009
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Hello nirim and yes I am dgcad from www.dgcad.com . I just downloaded and reinstalled RAC 2009 build 20080602_1900. I read that it was recommended to reinstall all the content and rendering materials library due to the improvements. So at the beginning of the install I clicked the configuration button to make sure I dd reinstall those items. Becasue I already had revit installed it may 'deselected those items' by default. I just did my first rendering with the new build and it looks really good. See image attached. Perhaps you should reinstall and check the configuration options. The render wasn't any faster but the quality looks better. I only used my laptop. A Toshiba Intel Pentium 1.86 GHz 1 MB RAM. Video > NVIDIA GeForce Go 6600
Can a sweep be applied to a roof ridge to model ridge capping??
Mon, Feb 4, 2008 at 11:01:27 AM
11
ridge control on a sloped roof
Tue, Jul 3, 2012 at 12:18:42 PM
Ridge Capping in 2009
Thu, Jun 12, 2008 at 1:46:14 AM
off center roof ridge
Wed, Jun 3, 2009 at 12:37:25 PM
Roof Ridge
Tue, May 9, 2006 at 1:15:59 PM
Page generation time: 2.1453
