Forums >> Revit Building >> Technical Support >> Column trim
Mon, Mar 28, 2005 at 1:24:52 PM | Column trim
jjk0
How to trim column using another object? In that case (see pic) I can't make workplane on ramp. Any suggestions?
Mon, Mar 28, 2005 at 5:51:05 PM | RE: Column trim
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Columns cannot be trimmed by any non perpendicular plane... You would either need to invidually adjust each column to go to the underside of the ramp... OR Create a new column which has a void built into the family to cut the top with an instance adjustable angle...
Tue, Mar 29, 2005 at 2:48:36 PM | RE: Column trim
jjk0
Thank's for info. In mechanical application we can find "Extrude up to .." So I have to wait for another Revit Smile
Trim on slanted column
Mon, Sep 8, 2008 at 1:20:01 PM
trimming trim corner.
Wed, Feb 1, 2012 at 12:09:41 PM
door trim stops short of floor
Wed, Jul 24, 2013 at 3:24:32 PM
Trim Roof Facia
Sun, Jul 3, 2016 at 12:18:25 PM
wood trim in revit arch 2009
Thu, Jul 31, 2008 at 4:53:32 PM
Page generation time: 1.5347
