17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Column Grid Question in Revit 2008
7 Posts No Rating |
I'm noticing a problem and curious if there's something that can be done or if I'm in deep trouble. It appears to me that when doing an elevation that is not perpendicular to the grids, the grids don't appear. I have a building that has two "wings, one that is 15 degrees different than the other. If I do an exterior elevation, the elevation will show the grids running perpendicular to that elevation, once I get to the "skewed" portion of the elevation those column grids do not show. The "skewed" grids in the first example will show if I create an elevation perpendicular to that building angle and the other grids won't. This also happens for interior elevations that aren't perpendicular to the grids. Any insight would be greatly appreciated.
Column Grid Text |
Tue, Dec 11, 2007 at 9:33:36 AM
Column Grid Line Weight |
Sun, Aug 13, 2017 at 3:05:53 AM
column grid visibility |
Wed, Nov 15, 2006 at 3:43:13 PM
Column to Grid |
Tue, Sep 8, 2009 at 4:09:31 PM
Column grid text too wide to fit in bubble |
Thu, Jul 1, 2010 at 8:32:06 AM
