Forums >> Community >> Newbies >> Glowing Walls
Sat, Apr 26, 2008 at 3:16:26 PM | Glowing Walls
mikol
Hello!
 I'm a brand new member and I have a couple of questions regarding wall transparencies and lighting.
 I'm working on a project with walls that I want to look like this:
http://www.nelson-atkins.org/images/H_BlochBuilding.jpg
I tried using  "Plastic - GFRP -  Glass Fiber Reinforced Plastic" as the material for the wall while checking the "Glow" box and turning the transparency to 100%. After that, I put a couple of uplighting strips by the walls and some spotlights pointing towards the exterior on the interior and rendered it. However, my walls did not glow or even hint at having any kind of transparency, regardless of using Raytrace or Radiate.
Any suggestions?
Sun, Apr 27, 2008 at 6:42:15 AM | Glowing Walls
4 Stars: 205 Votes
Hi, it's good if you can put a image of your render to look what's hapen, by the way, use RADIATE only for INTERIOR RENDERS....
Render has glowing walls 2012
Thu, May 16, 2013 at 1:18:58 AM
Furniture is 'glowing'
Mon, Sep 7, 2009 at 2:38:54 AM
Linear Lighting
Wed, Dec 27, 2006 at 1:14:19 PM
Revit TotD – 7.9.09: Glowing Sign, Self-Illumination Based Materials
Thu, Jul 9, 2009 at 2:20:36 PM
Rendering - light blub missing
Wed, Oct 26, 2011 at 5:26:19 PM
Page generation time: 0.5578
