Forums >> General Discussion >> Revit Project Management >> Need help with Family Content
Fri, Apr 25, 2008 at 2:44:42 PM | Need help with Family Content
MARS1276
1 Stars: 1 Votes
My problem is actually two-fold.  One, I have created 6 different families of pipe bollards.  I wish to group these under one family (as a content of different sized pipe bollards).  I am having a difficult time figuring out how to do this.
 Secondly, I would rather ike to create only one family of pipe bollards if I could.  I have gotten this to work before once, but any time I would choose a different size bollard, only the circle about it's base would change - not it's 3D extrusion, it simply stayed in place.
I have tried creating a pipe bollard with parameters established for height and radius.  And while the parameter for the height will adjust the 3D model accordingly, the parameter for the radius does not.  Like I said, it just creates a different size circle about it's base while the 3D object just stays in place.
Can anybody help me with this?
Fri, Apr 25, 2008 at 3:13:46 PM | Need help with Family Content
Study & take this family apart and you will see how it works.  You need to edit the extrusion to see the locks.
Sat, Apr 26, 2008 at 1:38:15 AM | Need help with Family Content
ToddSmith56
I am trying to load in a garage door, and my Revit program will not allow me to insert the garage doors.  My hard drive is allowing me to save it into a family, but the program will not allow me to install the door into the floorplan.  Any suggestions?
Mon, Apr 28, 2008 at 8:09:10 AM | Need help with Family Content
MARS1276
1 Stars: 1 Votes
Thank you for your reply WWHub.  I had actually done as you mentioned with a similar pipe bollard I had download from this very site.  I did not have much luck trying to reverse engineer it to create a family of different sized pipe bollards.  As I mentioned before, I got the size of the circle I used to draw it to change each time, but the 3D form itself would not.
I did manage to resolve this issue though.  What I ended up doing was simply trying another family type.  I opened the Structural Steel Columns and modified a simple pipe-column and that worked great!  I was also pleasantly surprised that they already had a family of a couple SCH40 steel pipes that we use ourselves for pipe bollards; complete with specifications and wall thicknesses included already.
Thanks!
Revit Family Content
Mon, Jun 3, 2019 at 3:14:21 PM
Revit Users and Content
Wed, May 11, 2016 at 8:57:38 AM
Content hatch - rotate with component
Mon, Apr 11, 2011 at 10:22:41 PM
Revit Families - content development - how difficult
Sun, Sep 25, 2016 at 3:23:11 PM
BIM Content Companies - How May We Help You?
Sun, Jan 3, 2016 at 10:44:59 AM
Page generation time: 7.2519
