Forums >> Revit Building >> Technical Support >> Adding New Materials to the Render Appearance Library in RAC 2009?
Search this ThreadSearch this Thread | Page 1 of 3 | 1 | 2 | 3 Next >>
Fri, Apr 25, 2008 at 1:08:56 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I have some Custom materials that I want to use in the Render Appearance Library but I'm not sure how to load them or save them so that they show up in the Render Appearance Library.  Any help would be great!  Thanks.
I'm using RAC 2009-
Dom
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Fri, Apr 25, 2008 at 1:19:56 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
jeremiah77769
1 Stars: 1 Votes
If you want to add a new material I believe the best way would be to go to Settings >>> Materials. Under Render Appearance, chose Replace and pick a material from the premade materials that comes close to the material you intend to make. From there you can change the image file to use the image you wish, then go from there assigning bump maps, reflectivity, etc.
I dunno if this helps, but this is how I have been going about making custom materials so far...
Fri, Apr 25, 2008 at 1:48:11 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I tried this and its not even showing up... weird.  Any other ideas?
 LHAA
Reno, NV USA
Fri, Apr 25, 2008 at 2:24:35 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
jeremiah77769
1 Stars: 1 Votes
After you have created the materials, you will still need to go into each family and assign the newly created material to it. I'm thinking if nothing is rendering (default materials) then the materials arent assigned to the families yet.
Fri, Apr 25, 2008 at 3:41:47 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I'm trying to add new custom materials to the Rendering Appearance Library.  I tried repathing the Render Appearance Path to the folder with my custom materials and still nothing showed up.  The materials are assigned to the families because I went back and double checked... I think it's because the image file and the Rendering Appearance don't match up?? I guess... and that I need to get my custom materials into the Render Appearance Library.  Thanks for the help so far... I know I've got to be close. Smile
 LHAA
Reno, NV USA
Tue, Apr 29, 2008 at 11:35:31 AM | Adding New Materials to the Render Appearance Library in RAC 2009?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Anyone?
 LHAA
Reno, NV USA
Tue, Apr 29, 2008 at 4:39:09 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I just want to make one of my JPEGs usable in the Render Appearance Library...
 LHAA
Reno, NV USA
Tue, Apr 29, 2008 at 6:54:42 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Thanks I got it!
 LHAA
Reno, NV USA
Thu, May 1, 2008 at 1:37:03 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
LIZARD2806
3.5 Stars: 7 Votes
How'd you do it?
**Using Revit Architecture 2009, 2011, and 2012**
Thu, May 1, 2008 at 2:57:43 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
My model was just being buggy but I fixed it.  First I created my custom png file, then I duplicated the Default material in the existing materials in Revit and gave it a new name, after that I changed Color: to Image file: and then browsed and found my png file that I created, I adjusted it to how I wanted it to look and then hit apply.  I closed out of the materials dialogue box and went to settings/options/Rendering tab and made sure that the additional render appearance paths had my folder with my new materials and I just hit ok.  I believe this loaded it into my project.  I did this before and after I created my new material in Revit just to make sure that it was there before... so I'm not sure if it truly reloaded it or if it was already there.
HTH
Dom
 LHAA
Reno, NV USA
Fri, May 2, 2008 at 12:00:19 AM | Adding New Materials to the Render Appearance Library in RAC 2009?
#11
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Please note currently the "Asset Library" for Mental Ray is read only and you cannot add to materials to this to use as a base for making Revit Materials.  You can only use the existing materials as a basis in this version.
Regards,
Chris.
Mon, May 5, 2008 at 6:21:45 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
#12
stylewise
Does this mean I cannot create a new render appearance in the appearance library? I want to create a new render appearance for a metal roof profile. i.e - Material - Colorbond roof - Render appearance - image I have saved. Can I do this without over riding any of the existing materials? HELP PLEASE..
Mon, May 5, 2008 at 6:56:15 PM | Adding New Materials to the Render Appearance Library in RAC 2009?
#13
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I think I'm really going to have a put a post on blog about this as a lot of people are having issues getting their head around the process.
Lets put it into a tree diagram:
Mental Ray Asset Library (read only) - presetup with Revit (stored in your C Drive Library)
                                 V
Revit Material Library (fully customiseable) - Accessed by Settings-->Materials-->Rendering tab (stored in a project only)
We can't currently add anything to the top level.  Basically there is enough variety of materials to select one of the Asset Library materials and simply manipulate it to achieve what you are after.  You can achieve pretty much anything.  The Generic option gives you access to nearly all customisation.
So you can certainly create what you are after and I've actually already setup colobond materials for all different sheeting profiles.
HTH.
Regards,
Chris.
Mon, May 26, 2008 at 3:55:16 AM | Adding New Materials to the Render Appearance Library in RAC 2009?
#14
SeaGarden
I'm having trouble using a custom jpg-image in a material. Jusing the generic material as a base, the preview goes black when updating. The strange thing is that when replacing the image with others it shows fine. I've tried to adjust the scale and just about everything else I can think of, with no luck. Also tried to save as png and bmp from Photoshop to see if it had something to do with the jpg-format. Any suggestions?
Thu, Jun 5, 2008 at 1:38:52 AM | Adding New Materials to the Render Appearance Library in RAC 2009?
#15
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, is the only way to get a custom surface pattern on a material by using an image to create the pattern? I want a tiled pattern where each tile is 2390mm long and 590mm high. In RAC2008 it was easy to create this pattern, but I'm having trouble doing it in RAC2009. Could someone please tell me how to do this? Im using RAC2009.
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
adding an image to the render appearance library
Wed, Dec 16, 2009 at 6:08:06 PM
Render Appearance Library - Reloading
Wed, Mar 18, 2009 at 1:04:31 PM
Revit 2009 Additional Render Library - Anyone know any about it
Fri, Sep 5, 2008 at 9:01:47 PM
Revit 2009 - Additional Render Appearance Paths
Tue, Sep 2, 2008 at 7:44:11 AM
using revit 2008 project in revit 2009...plz help
Tue, May 27, 2008 at 8:44:38 AM
Page generation time: 0.8372
