Forums >> Community >> Newbies >> WALL TAGS - VERY BASIC QUESTION
Fri, Apr 25, 2008 at 11:03:18 AM | WALL TAGS - VERY BASIC QUESTION
Scott8899
REVIT HELP DOES NOT HAVE MUCH INFO. ON WALL TAGS...HOW ARE WALL TAGS SET UP AND HOW DO I USE THEM?  FOR EXAMPLE WHEN I TAG A WALL IN MY PROJECT THE WALL TAG HAS A QUESTION MARK BUT IF I TRY TO ADD A VALUE IT SAYS I WILL BE CHANGING THE PARAMETER FOR ALL TAGS?
Fri, Apr 25, 2008 at 11:19:34 AM | WALL TAGS - VERY BASIC QUESTION
REVIT's help has a lot of info on tags, you just haven't looked far enough yet.  When you pull up tag, you will see a whole list of related help topics.  A wall tag is just one type of tag.  These are multi-category tags and you can create as many as you need for a project using built in and user created shared parameters.
Take the time to learn about shared parameters and multi-category tags because this is part of the power of BIM.
Look in help under tag .... tagging with shared parameters ... creating a multi-category tag.
You will also need to look at parameters...  multiple subjects you need to read here.
Basic Wall as Curtain Wall panel transparency incorrect.
Wed, Nov 23, 2011 at 9:37:16 PM
Basic wall + Curtain wall
Fri, Aug 22, 2014 at 1:28:03 PM
REVIT Architecture 2009 Basic Architectural Convention question [ 1 2 ]
Tue, Oct 21, 2008 at 8:19:58 AM
15
wall by face question 2010
Wed, Apr 18, 2012 at 12:48:17 PM
Wall hosted Families question
Thu, Jan 3, 2008 at 7:04:01 PM
Page generation time: 4.5761
