Forums >> Community >> Newbies >> 256MB video card - NVIDIA GeForce 8600 GTS
Fri, Apr 25, 2008 at 10:49:39 AM | 256MB video card - NVIDIA GeForce 8600 GTS
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is this a good card??  My file is tremendously slow in elevation views.  When I work on something, everything has a 2-3 second delay.  Not good considering my productivity has fell to the floor.  I need to get this fixed and want to get the right video card from NVIDIA.  That's who our IT guy goes through.  Suggestions?  Attached you'll see a video of how slow this is...  Thanks,
Lorne
Denver, CO
Revit Architecture
Fri, Apr 25, 2008 at 11:12:53 AM | 256MB video card - NVIDIA GeForce 8600 GTS
coreed
coreed Avatar
4 Stars: 16 Votes
do you get this delay on all files, or just what would be considered large files?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 25, 2008 at 11:21:39 AM | 256MB video card - NVIDIA GeForce 8600 GTS
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Well this is our first project that is in CDs in Revit.  We have lots of others that are in SD and DD phases, so not as much information in the model itself.  The file is only 35 MB though.  I went through the Review Warnings and got it down to 1 and it was still slow.  I also purged out everything not used.  So 0 items to purge and 1 warning (which I'm about to fix).  I've also done file maintenance on it, and opened the file with Audit and resaved our locals to clean up any unwanted file information.
Other than that, I don't know what else it is besides video card.   I have 3.25 GB of ram.  Duo Core Processor.
Denver, CO
Revit Architecture
Fri, Apr 25, 2008 at 1:50:50 PM | 256MB video card - NVIDIA GeForce 8600 GTS
TJKENNEDY
3 Stars: 2 Votes
That's the card I have and it seems to be working alright for me.
Fri, Apr 25, 2008 at 2:03:36 PM | 256MB video card - NVIDIA GeForce 8600 GTS
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
What then could it be?
Anything else as far as computer hardware goes?  My coworker has a newer machine and his works just fine.  Same file.
Denver, CO
Revit Architecture
Wed, May 7, 2008 at 7:06:25 PM | 256MB video card - NVIDIA GeForce 8600 GTS
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
thats a gamers card
 get a quadro fx or a firegl.
Edited on: Wed, May 7, 2008 at 7:08:37 PM
Edited on: Wed, May 7, 2008 at 9:32:00 PM
Wed, May 7, 2008 at 7:49:50 PM | 256MB video card - NVIDIA GeForce 8600 GTS
teddynugget
teddynugget Avatar
3 Stars: 2 Votes
Have you enabled OpenGL hardware Acceleration in revit options under the Graphics tab?
This allows revit to use the video card to boost performance, will difinitely help in the elevations when shadows are turned on.
Thu, May 8, 2008 at 3:46:59 PM | 256MB video card - NVIDIA GeForce 8600 GTS
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello,
Ok well I found out what the issue was.  After I got a new graphics card, I still had the issue.
Yes, I did check the Open GL in settings.  That just made it worse and it crashed.
Then I realized our IT guy installed Revit from our disk.  We have a new build on our server.  So I reinstalled on that, and it worked!  After all this, I finally figured it out and it was soo simple.
Thanks for all yoru suggestions,
Best,
Lorne
Denver, CO
Revit Architecture
looking for a video card recommendation
Tue, Sep 3, 2013 at 7:04:52 AM
Nvidia GeForce GTX 560 Not Recognized in 2012
Sat, Jan 12, 2013 at 5:47:37 AM
Any REAL issues in using nVidia GeForce Cards vs. nVidia Quadro FX cards???
Mon, Feb 10, 2014 at 9:12:20 AM
image underlay window size limitations 2014/16
Mon, Mar 21, 2016 at 8:56:59 AM
Revit 2010 Memory reaching critical limit
Mon, Aug 31, 2009 at 11:03:10 PM
Page generation time: 0.2156
