Forums >> Revit Structure >> Tips & Tricks >> Analytical Modeling Issues
Fri, Apr 25, 2008 at 9:36:21 AM | Analytical Modeling Issues
mjs611
I am currently working with Revit Structure 2008 and am constantly having issues with discrepancies between my physical and analytical model lines.  I have found work arounds for many of the complications but I am stuck with one thing.  I am trying to frame a beam system into a masonry wall.  The analytical line of the wall is not directly in the center of the wall.  I cannot get the beams in the system to "reach" the analytical line of the wall.  I have tried the "adjust analytical" tool with no effect.  If anyone has a work around for this issue I would appreciate it.
Wed, May 14, 2008 at 12:03:14 PM | Analytical Modeling Issues
Sandoz
1 Stars: 1 Votes
This may be obvious but have you tried the 'align' tool?  I haven't come across this issue because I'm still trying to work out how to model correctly.  I'm sure you have but just in case.
Adjusting the analytical line in a revit family
Fri, Mar 5, 2010 at 9:16:30 AM
Analytical Line
Tue, May 23, 2006 at 6:00:18 AM
Deactivate Analytical Truss and Slab
Wed, Feb 9, 2011 at 8:10:56 AM
Analytical Lines creates blank space in schedule in revit str 2014
Thu, Sep 11, 2014 at 8:10:30 AM
Resetting/fixing the analytical model (Revit Structure 2014)
Wed, Jan 15, 2014 at 8:56:48 AM
Page generation time: 0.1489
