27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> floors dont shadow in elevation?
hi, these terrasses are constructed with a floorslab and a floorslab edge, in elevation the floor doesnt seem to be dropping any shadow ( and the floor is active in that view, when i hide the slab-edge the floor is visible, ) what is going on here? Kind regards,
Edited on: Wed, May 21, 2008 at 8:18:21 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
anybody?
peace is the path."
Mahatma Gandhi.
Did you get this figured out? I'm having the same isue and can't figure out why the floor isn't casting shadows... Anyone find a resolution to this yet?
Anyone? Anyone?
Playing around with this again, I may have something to try. Go to the sun settings and make sure that the level selected is below the slab level that you're wanting to cast the shadow. If that doesn't do it, uncheck the "ground plane at level". Both of those ended up fixing it for my situation.
It was the slab level thing, thanks!
You're welcome! Funny how something can stump you, then 4 months later a solution comes to you in minutes after looking at it again. So... thank you for bringing it back up, now my problem is solved as well.
3d elevation shadow problem |
Fri, Feb 15, 2013 at 5:07:00 PM
Elevation Shadow Study |
Sun, Sep 20, 2009 at 8:51:59 AM
Elevation Markers: visible on all floors |
Mon, Nov 7, 2011 at 12:24:27 PM
Shadow Casting |
Thu, Feb 12, 2009 at 10:00:48 PM
Doors make a gray shadow in Sections |
Wed, Apr 7, 2004 at 10:39:43 AM
