Forums >> Revit Building >> Technical Support >> IES/MEP
Fri, Apr 25, 2008 at 2:45:32 AM | IES/MEP
dianajohn
Wondering is any one can help. In our office we are using 2008 and currently are documenting a $60M office development in RAC. We are mid way thru our DD stage but are having problems with the transfer of our BIM model INto the IES format. the main problem is the sunscreens outside the building. Theses where created as Generic families - but did not transfer to the IES model. I changed them to a Window Family but no success. Has anyone had similar problem or does anyone have a work around solution.
John A.
Sat, Apr 26, 2008 at 5:11:39 PM | IES/MEP
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
Are you using the direct link with IES <VE> or exporting to a gbXML or ODBC database? Generally the direct link works a little better than exporting the information out.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Sun, Apr 27, 2008 at 2:07:48 AM | IES/MEP
dianajohn
The export is being done thru gbXML.
Sun, Apr 27, 2008 at 12:59:48 PM | IES/MEP
Eddieboarder91
4 Stars: 8 Votes
I am not sure with the add-on that IES has provided if there is a direct link inside RAC but i know there is in RME i would certainly try this if you can.
Exporting Material Properties from Revit Architecture & MEP to IES<VE>
Mon, Apr 6, 2009 at 4:54:39 PM
lighting analyse with IES
Mon, Apr 28, 2008 at 1:56:56 AM
IES files in Revit
Mon, Feb 6, 2017 at 4:00:14 PM
SketchUp and IES
Fri, Aug 29, 2008 at 1:18:34 PM
Problems importing Revit model into IES VE
Thu, Jan 6, 2011 at 10:04:14 AM
Page generation time: 0.0869
