Forums >> Revit Building >> Technical Support >> Rendering 2009
Wed, Apr 23, 2008 at 10:57:02 PM | Rendering 2009
parleyburnett
3 Stars: 2 Votes
I am somewhat new to rendering, and especially rendering in 2009 for that matter.  Can I get some critique on this rendering and maybe find out what quick settings I can tweek to get a better look?  Thank you!
-Parley
Thu, Apr 24, 2008 at 8:11:28 AM | Rendering 2009
Dafpfy
3.5 Stars: 11 Votes
putting in a lighting flash and an photoshop overlay with rain would make it look better :p
just kidding,
set the sky to lichtblue? maybe that will reflect on your model , dont have any experience with 2009
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, Apr 24, 2008 at 8:20:16 AM | Rendering 2009
Dafpfy
3.5 Stars: 11 Votes
and i gues your windows are mirrors?
it kinda looks like you just used the front wall to render and the terrein just continues behind your walls,
peace is the path."
Mahatma Gandhi.
Tue, Jun 10, 2008 at 6:17:31 PM | Rendering 2009
psemrau
Get more dramatic shadows by moving the light source (or add a second one). Experiment with intensity and location, try a subtle light above and behind the building, it might add some dimension by separating it from the background too.
And also add some entourage elements and vegetation, that gives life to your rendering.
Avoid doing elevation view angles, because they tend to look flat, try some camera views at pedestrian eye level, look at the building at an angle, etc.., that adds a little bit realism, although you might need a few views to show the entire building.
Tue, Jun 10, 2008 at 8:59:24 PM | Rendering 2009
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
I agree with psemrau inregards to changing the sun location and adding entourage (cars, trees and people for scale.
Have a play with the exposure so you dont get a washed out image.
Also, have a look at refining the textures you are using. Make sure they ar 100% tileable.
If all else fails, hand ball the model to your viz guy for him to export into Max or Maya.  But you should be able to get something decent out of Revit.
Wed, Jun 11, 2008 at 8:44:47 AM | Rendering 2009
JustinT
You might find this useful...
I go this a while back from Revit3D blog site. You have to sign up to his site as a member and I hope it's ok to share this info in this way.. password for PDF file is    earthhour
Just so I don't get into trouble please take a look at this great Revit blog site http://bimboom.blogspot.com/
There is nothing to say this file can't be shared that I can see - but anyone can sign up on the site for free and download it anyway.
Anyway it explains all about the Mental Ray settings etc...
Justin
www.revitup.co.za
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Helping rendering in 2009
Sun, Apr 19, 2009 at 8:24:59 AM
Rendering function greyed out in Revit Arch 2009
Mon, Feb 16, 2009 at 4:53:18 AM
Rendering in 2009
Wed, Jun 11, 2008 at 3:18:08 PM
Page generation time: 0.4681
