Forums >> Community >> Newbies >> Inclinanated wall dimensions
Wed, Apr 23, 2008 at 8:43:20 PM | Inclinanated wall dimensions
Diablo1
Hi
I am trying to place dimensions for inclinated walls but I can not place this dimensions, does anybody know how to place dimensions to angle walls?
Fri, Apr 25, 2008 at 10:18:55 AM | Inclinanated wall dimensions
LIZARD2806
3.5 Stars: 7 Votes
Assuming you are dimension to, say an exterior corner.....  enter the dimension command, then go to the first corner.  press the tab key repeatedly until only the point in the corner is highlighted, left click, then go to the other corner and do it again.  Once you have those two points, it will create a string in a straight line between the two.
Temporary Dimensions and Wall centerlines
Thu, Oct 20, 2011 at 1:31:20 PM
Face to face wall dimensions
Mon, Jul 11, 2011 at 11:13:34 AM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:10 AM
Hiding specific dimensions
Mon, Jun 10, 2013 at 7:20:50 AM
Setting default point for witness dimensions
Mon, Mar 21, 2005 at 11:17:16 PM
Page generation time: 0.8768
