Forums >> General Discussion >> Revit Project Management >> To Link or to group room types? Which is the best way to go? For Hotel room type
Wed, Apr 23, 2008 at 11:06:43 AM | To Link or to group room types? Which is the best way to go? For Hotel room type
revitdude
Currenty working on a hotel... I was thinking the new feature in 2008 was the way to go, but reading about some of the Linking issues here at RevitCity, I'm not so sure.  Please advise on which way to go grouping room types or linking them?
Thanks,
Jack
Wed, Apr 23, 2008 at 11:11:35 AM | To Link or to group room types? Which is the best way to go? For Hotel room type
I don't group different room types but I do group elements that make up a room.
Wed, Apr 23, 2008 at 11:36:12 AM | To Link or to group room types? Which is the best way to go? For Hotel room type
revitdude
So if a room type changes.  you modify each one independently? Wall changes, furniture layout etc...
In autocad xrefs handel this nicely, would be nice if revit did too.
Do you have a good example of your room group setup?
Thanks,
Jack
Wed, Apr 23, 2008 at 12:26:02 PM | To Link or to group room types? Which is the best way to go? For Hotel room type
I group my room types at the same "insertion" point.  That lets me swap groups at the pull-down in the options bar.  2008 allows you to exclude elements to a group on an instance bases.  I think this works much better that AutoCAD.
I had also included rooms within my group but you need to watch out what you include because of future editing times.  When you change a group, all of instances of that group have to be changed.
Wed, Apr 23, 2008 at 1:59:48 PM | To Link or to group room types? Which is the best way to go? For Hotel room type
revitdude
WWHub,
Thanks for your help and insight... it's much appreciated!
Jack
Mon, Apr 28, 2008 at 3:21:23 PM | To Link or to group room types? Which is the best way to go? For Hotel room type
revitdude
WWHub,
One issue that come up is... that walls that are in a group, will be used on a different floor may have different floor heights?  Have you ran into this?
Thanks,
Jack
Mon, Apr 28, 2008 at 3:37:08 PM | To Link or to group room types? Which is the best way to go? For Hotel room type
If the wall heights are offset a fixed distance off the floor above, they should not be a problem.
Mon, Apr 28, 2008 at 4:42:21 PM | To Link or to group room types? Which is the best way to go? For Hotel room type
revitdude
WWHub,
 I think I got this issue firgured out, groups with taller or shorter walls need to be a mod/rev of base group...
Group 1a, Group 1b, etc...
Thanks,
Jack
Rooms Areas For Large Hotels
Mon, Dec 2, 2013 at 8:04:09 AM
Hotel rooms as groups [ 1 2 ]
Wed, Jan 30, 2013 at 10:50:12 AM
16
Revit 2010-Hotel room multiple room units
Sun, Jul 19, 2009 at 1:29:33 PM
Callout of Typical Rooms in Hotel/Multifamily Residential Project
Wed, Mar 12, 2014 at 7:38:36 AM
Room Tags - Tagging Multiple Rooms as One
Tue, Feb 19, 2008 at 1:25:28 PM
Page generation time: 0.7502
