Forums >> Revit Building >> Technical Support >> RPC and revit 2009
Wed, Apr 23, 2008 at 9:13:14 AM | RPC and revit 2009
R7oky
I have a couple of demo rpc files that i have downloaded from archvision, how to i load these into revit 2009, as before in 2008 you could go to edit the male componant family and search for the file and add the new rpc file from you localtion you search for. 2009 is different i can not seem to find a way of searching for the path or file, can some one help me on how to get my rpc files into revit 2009.
Many thanks
Thu, Apr 24, 2008 at 12:19:34 PM | RPC and revit 2009
jeremiah77769
1 Stars: 1 Votes
As far as I know you will need to edit the family of the RPC you wish to update. Once in the family editorr you will need to guide the RPC location to the new target you want to add. I think thats how I went about adding them to mine, it does work I can say that....
Fri, Apr 25, 2008 at 10:42:14 AM | RPC and revit 2009
2005Mark
3.5 Stars: 2 Votes
I have just gone to Archvision web site and clicked on Revit. It only supports upto 2008. I should imagine that they are working on 2009 version now.
Mark
Fri, Apr 25, 2008 at 1:11:54 PM | RPC and revit 2009
jeremiah77769
1 Stars: 1 Votes
The old RPC's do work in 2009. I've been testing some of them and I havent had any problems so far. I do believe that the animated RPC's dont work, as of yet, so you might take that into consideration.
Tue, Jun 24, 2008 at 1:13:23 AM | RPC and revit 2009
leenahol
How do you define the right path? There's the rendering library of Revit wich contains some RPC, but I can't find a way to add any others. I've got RPC-objects that have been purchased so  it would be nice to use those too... So they're in a diffrent place on my computer than the RPC-objects of Revit, how could I get them too in the family, without interfering to the RPC-objects of Revit (and by the way some of the purchased are same as the ones in Revit library)
Tue, Jun 24, 2008 at 4:29:05 AM | RPC and revit 2009
4 Stars: 205 Votes
Hi, go to "SETTINGS-OPTIONS...-FILE LOCATIONS" in bottom you have the path from "Libraries" pick in button to ADD a library, give them a name "RPC" and in the right pick in button "..." to found the location i.e. "C:\RPC"
Sun, Oct 26, 2008 at 3:05:43 PM | RPC and revit 2009
frcprogetti
Turorial in italien, create and using RPC in revit
http://www.frcprogetti.com/news/2008/10/22/tutorial-creare-gli-rpc-per-revit-architecture
Mon, Jun 1, 2009 at 9:24:49 PM | RPC and revit 2009
kakkoihamo
where can i download RPC from?
anyone????
ありがあとう
日本より
Mon, Jun 1, 2009 at 11:16:39 PM | RPC and revit 2009
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Try here: http://www.accustudio.com/index.php?option=com_remository&Itemid=0&func=select&id=13
Mon, Jun 1, 2009 at 11:55:15 PM | RPC and revit 2009
kakkoihamo
thanx dude
どうも ありがとう
日本より
Revit 2009 - RPC's
Thu, Sep 9, 2010 at 3:16:34 PM
2009 RPC files
Thu, Sep 9, 2010 at 2:47:12 PM
importing other RPC content in revit 2009??? plz help
Sun, Oct 26, 2008 at 3:06:05 PM
Revit 2009 - RPC Archvision Content
Tue, Jan 6, 2009 at 10:46:29 AM
cannot see Decal and Rpc elements in new project 2009
Sun, Nov 23, 2008 at 5:17:13 AM
Page generation time: 1.9021
