Forums >> Revit Building >> Technical Support >> Help I can't edit my drawing...Receiving error message
Tue, Apr 22, 2008 at 11:13:07 PM | Help I can't edit my drawing...Receiving error message
hyperlite986
 I accidently saved a file as a central file and now I can't edit my drawing at all.  I have it due next week for class and need some help.  My teacher didn't know how to fix it either.  This is the error message I get when I try to edit anything in my drawing.
     [  Can't edit the element until 'caduser' resaves the element to central and relinquishes it and you Reload Latest. ]
Any help would be greatly appreciated.   Thanks
Wed, Apr 23, 2008 at 7:05:38 AM | Help I can't edit my drawing...Receiving error message
Someone ...maybe you... was logged into REVIT as 'caduser' and did not relinquish all when they closed the file.  This is a simple fix, open REVIT and go to settings - options, change the username to "caduser", then open the file, "relinquish all mine", save - close the file.  Now, change your user name back and all will be ok.
Mon, Apr 28, 2008 at 7:18:33 PM | Help I can't edit my drawing...Receiving error message
hyperlite986
Thanks for the help it worked.
revit 2009 error message
Fri, Sep 3, 2010 at 8:23:07 AM
"Can't Regenerate Family ____. Edit Family to modify it." Error message
Wed, Aug 26, 2020 at 11:19:36 AM
Error Message
Wed, Sep 16, 2009 at 8:10:27 PM
ERROR MESSAGE: STAIRS - rises not intersecting boundries?
Tue, Aug 19, 2008 at 9:12:33 AM
Error Message
Fri, Feb 18, 2011 at 2:24:25 PM
Page generation time: 1.7591
