Forums >> Revit Building >> Technical Support >> Sloped Fascia
Tue, Apr 22, 2008 at 4:34:05 PM | Sloped Fascia
tawieser
I have a problem with a stepped fascia on a sloped roof.  The corners will not miter together.  My walls are also angled which might be complicating the issue.  I have used the roof fascia to alter the fascia and to place it.  Does anyone know how to make the stepped fascia miter together?  Any help would be greatly appreciated.
Thu, Apr 24, 2008 at 8:25:05 PM | Sloped Fascia
LIZARD2806
3.5 Stars: 7 Votes
a picture would be a helpful.....but a silly question, is the stepped miter making a perfect 90 degree turn where you want it to miter?  If not, it might even be hard to do it in the field.....
Fascia on Sloped Glazing
Tue, Aug 23, 2005 at 11:58:53 AM
How to miter a fascia on a sloped roof?
Fri, Aug 24, 2012 at 7:48:23 AM
fascia on two different sloped roofs
Thu, May 28, 2009 at 1:01:04 PM
Sloped Roof Fascia
Wed, May 29, 2013 at 1:23:20 PM
Revit 2012 fascia limitations??
Sat, Oct 12, 2013 at 2:06:35 AM
Page generation time: 0.0677
