Forums >> General Discussion >> Wishlist >> Wish Match Properties tool worked while adding new walls or components.
Tue, Apr 22, 2008 at 9:32:04 AM | Wish Match Properties tool worked while adding new walls or components.
just
Offen I am adding walls next to walls that were drawn previously. I would like to match the properties of the existing wall or other family. Scrolling throught he browser can be time consuming.
Tue, Apr 22, 2008 at 9:36:11 AM | Wish Match Properties tool worked while adding new walls or components.
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Just use the Create Similar Button. It is located in the toolbars at the top of the screen. This will inherit the family and type of any object selected and put you into the right command to place another instance of an object.
Tue, Apr 22, 2008 at 9:43:10 AM | Wish Match Properties tool worked while adding new walls or components.
coreed
coreed Avatar
4 Stars: 16 Votes
you can also select the wall you want and right-click and select Create Similar
HTH
Tue, Apr 22, 2008 at 9:48:50 AM | Wish Match Properties tool worked while adding new walls or components.
just
perfect!
Thanks
Matchline tool
Wed, Dec 12, 2007 at 2:46:26 PM
Create form tool for components other than mass - Revit Architecture 2012
Mon, Oct 20, 2014 at 4:15:58 PM
Revit 2013 making walls by faces and some walls are very strange... please help!
Wed, Jun 19, 2013 at 7:05:58 AM
Detail Components with Demo Objects
Tue, Dec 30, 2008 at 4:34:29 PM
Adding options in the properties for doors
Tue, Sep 6, 2011 at 7:46:17 AM
Page generation time: 1.2299
