Forums >> Revit Building >> Technical Support >> revit 2008_ lineweights in 3d views vary.
Tue, Apr 22, 2008 at 2:09:15 AM | revit 2008_ lineweights in 3d views vary.
carlamma
I don't understand why when i set 3d views and print them, in some views the lineweights are very thin (which is suitable), and in other, particularly aerial views, the lineweights are very heavy (terrible), yet all view settings are the same.... please help!
Tue, Apr 22, 2008 at 8:49:57 AM | revit 2008_ lineweights in 3d views vary.
fraz
Sometimes when you make a 3d view, you change the camera's original settings in real time (i.e. zooming, panning, etc.) which results to changing the 3d view's image size or resolution. Try changing the image size to your desired print size
Lineweights Issue
Thu, Nov 17, 2005 at 6:05:35 PM
Lineweights Question
Wed, Aug 3, 2005 at 4:03:11 PM
Revit lineweights
Wed, Jan 28, 2015 at 9:31:49 AM
Revit Lineweights not printing correctly
Fri, Jun 14, 2013 at 1:27:49 PM
resetting lineweights
Wed, Jun 30, 2010 at 9:46:11 PM
Page generation time: 1.6421
