24 Users Online (22 Members):
Forums >> Revit Structure >> Technical Support >> Circular Chain of Reference
1 Posts No Rating |
I keep getting an error message that says there is a circular chain of reference among highlighted elements. I can't seem to get around this. Any ideas?
I have seen this and I am pretty sure it means that there is a confilct with some of the constraints/parameters. It sometimes is found in the sketch mode of an object. I usually just try to find out which items are involved in the conflict and by trial and error method I usually can fix the issue.
3 Posts No Rating |
easy way around this, in sketch mode, select your sketch line and mirror (with copy unchecked) then mirror at the same axis back to its original position, this will get rid of sketch dimensions and constrains, which you can't see!
Circular Chain Reference |
Mon, Aug 14, 2006 at 5:09:53 PM
Wish List - Kill Circular Chain of references |
Thu, Apr 10, 2008 at 1:51:30 PM
Error Message: "Circular Chain of Reference" - help requested! |
Thu, Nov 24, 2011 at 9:34:08 PM
circular chain refernce |
Fri, Jul 21, 2006 at 9:17:19 AM
Circular chain of refenrences (Yes, another one...) |
Tue, Jun 21, 2011 at 12:35:49 PM
