10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Having Problems Loading and Inserting Family into Project...
8 Posts No Rating |
I am trying to build a family for a paneled wall system and am having trouble getting it to insert into the project the way I want. I would like to make it so that I can insert the panel and then insert a second one which will snap to the end of the previous panel. Can anyone tell me the simplelist way to make this happen? Thanks, Matt
----------------------------------- Matthew Brownwww.revit-lution.come-mail: studio@revit-lution.comphone: (850) 776-3527 |
You can do this by drawings a set of ref planes that intersect at the point you want to attach at and at the other end. You will then select each of the insertion side ref planes and set it to "Defines Origin" in the properties. (you have to do each one seperately) Also make sure that they are set to "Strong Reference. Once this is done and the family is loaded in a project, you can place them by hovering the cursor over the previous on and it should highlight the strong references. I won't automatically select the point but it will try to snap to the strongest ref planes.
8 Posts No Rating |
Thanks, it seems to be working now.
Revised family not loading into existing project |
Mon, Jun 27, 2011 at 8:22:16 AM
Inserting a 2D Component into a new project sheet [ 1 2 ] |
Fri, Jun 22, 2012 at 8:39:40 AM
20
Error Loading Profile Family |
Sun, Nov 21, 2010 at 12:31:22 PM
Differences in families while loading them into project |
Wed, Oct 27, 2010 at 7:02:17 AM
Inserting Structural Trusses |
Fri, Apr 11, 2008 at 8:56:28 AM
