10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Transparent dwg import
4 Posts No Rating |
Hello, I have tried to find the answer to my problem on this forum with no luck. The problem is when i import a ADT 2007 3d model into Revit it appears in 3d view to be transparent. All walls and doors are transparent ! I´ve tried to change the import settings in all combinations with no luck. I´ve also tried to change "Model Graphics Style" between shading, hidden lines.... Can anyone help me !
You probably don't have any 3dfaces in your AutoCAD dwg, just 3d lines. That's been my experience with ADT objects.
4 Posts No Rating |
Ok, is there any easy way to create 3d faces in Adt before importing to Revit ?
That's hapen with another version of ADT, i tried with old model create with ADT 2002 and Revit don't (i don't no why) recognize ACIS solid with this model of ADT, just recognize only the elements create with "Extrusion", so, try this: - open the file with ADT 2008 then export with IFC, in Revit import IFC file, it works...
Import DWG problem with size |
Mon, Dec 6, 2010 at 7:33:32 PM
DWG import shaded colors |
Sun, Apr 26, 2009 at 1:53:03 PM
Can't import dwg or dxf to RS2008 |
Wed, May 30, 2007 at 10:36:07 PM
dwg import bring to front |
Fri, Jun 27, 2008 at 9:46:56 AM
Autocad MEP Import Transparent Materials |
Mon, Mar 21, 2011 at 11:18:59 PM
