14 Users Online (12 Members):
Forums >> Revit Systems >> Technical Support >> DETAILS IN SECTION CALLOUT
Can i get the details (detail lines/detail components/etc) to show up in a callout of a section? John
9 Posts No Rating |
have you tried "copy to clipboard" then "paste aligned"? if there's plenty of details to be copied, make a window selection then use the filter command to individually check /uncheck items in your selection. or...if your desired callout scale and section scale are not too different, try "duplicate with detailing" then change the scale and name of the view to "callout of section...". i hope this helps
Callout Details |
Wed, Sep 25, 2013 at 10:31:24 AM
Section callout missing |
Mon, Dec 16, 2013 at 4:00:09 PM
can Callout duplicate detailed drawn on section view? |
Thu, Oct 4, 2012 at 11:05:02 AM
Callouts/Details |
Fri, Jan 25, 2008 at 4:01:11 PM
Using 2d group for Wall section, section details called out from wall section? |
Fri, Oct 9, 2015 at 10:50:56 AM
