Forums >> Revit Building >> Technical Support >> Modify / remove opening
Sat, Apr 19, 2008 at 4:52:12 AM | Modify / remove opening
HKarlo
(using Revit Building 9)
I cut an opening in a floor. How do I modify my opening, or remove it? If I try to modify the floor, revit is only showing me the original linework of the floor, not the linework of the opening!
Sat, Apr 19, 2008 at 7:27:26 AM | Modify / remove opening
coreed
coreed Avatar
4 Stars: 16 Votes
if you created the opening using the Opening Tool then the sketch boundary for the opening is independent of that for the  floor.
see video
http://screencast.com/t/c3cdfImqvg
Edited on: Sat, Apr 19, 2008 at 7:33:44 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Apr 24, 2017 at 1:40:15 PM | Modify / remove opening
RockFish
5 Stars: 2 Votes
Bump because I can't seem to figure this out 9 years later.
Mon, Apr 24, 2017 at 1:45:00 PM | Modify / remove opening
RockFish
5 Stars: 2 Votes
And to clearify, my cut opening is on a sloped roof, created by profile and I can't seem to select the vertical opening cut I created with the vertial opening cut tool/button.
Mon, Apr 24, 2017 at 8:11:51 PM | Modify / remove opening
mansell5
3.5 Stars: 4 Votes
in a 3d view, position mouse on the area or spot in question, then hit tab key cycling through the options.then click and edit.
Modify Window opening
Thu, Oct 26, 2006 at 6:23:52 PM
help me door and windows pleaseeeeeeeeeeeeeeee
Tue, Oct 17, 2006 at 10:54:09 AM
Combining two gable roofs
Tue, Oct 22, 2013 at 8:52:35 AM
roof opening
Tue, Sep 18, 2007 at 11:45:12 PM
remove web openings from view
Fri, May 30, 2014 at 3:52:50 PM
Page generation time: 1.8265
