Forums >> Community >> The Studio >> Revit 8
Thu, Mar 24, 2005 at 6:44:01 AM | Revit 8
rick_tiger
Hello People Has any one noticed that for example the australian autodesk website has Revit 8.0 but on the USA website you can only download Revit 7. Can any explain to whats going on? Richard
Sun, Mar 27, 2005 at 10:59:43 PM | RE: Revit 8
SCOTTY V
i THINK YOU WILL FIND THAT IS THE BETA VERSION OF 8, THE FULL VERSION WILL BE RELEASED AT THE END OF APRIL, SO I HEAR.
Mon, Mar 28, 2005 at 8:28:00 PM | RE: Revit 8
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Yeah, there is a beta version of 8 out there for some people to test but Autodesk seems to be pretty serious about it not getting out to the general public quite yet... or so I hear Post edited on 2005-03-28 20:28:21
Hiroshi Jacobs
Mon, Mar 28, 2005 at 9:42:03 PM | RE: Revit 8
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Only Autodesk Subscription members have access.
Tue, Mar 29, 2005 at 1:53:48 AM | RE: Revit 8
Scott Davis
3.5 Stars: 3 Votes
Quoting Mr Spot - 2005-03-28 21:42:03
"Only Autodesk Subscription members have access."
every Revit owner is on subscription.
Post edited on 2005-06-13 04:01:25
Tue, Mar 29, 2005 at 2:24:36 AM | RE: Revit 8
Steve_Stafford
5 Stars: 2 Votes
Quoting Scott Davis - 2005-03-29 01:53:48
Not quite, if you don't renew your subscription you can't/aren't.
Only the person who manages the Autodesk account and those that person identifies are able to log in to the subscription site. It takes additional permissions to download from the site too. A firm can only allow in as many people as you hold licenses for if I remember correctly, unless something has changed.
So it is quite possible a Revit user may not be able to access the subscription site or participate in any beta programs offered by Autodesk.
P.S. Hiroshi...the quoting doesn't work very well. Mr. Spot's quote shows up as Scott's and Scott's shows up in my text...I can't fix it either.
Post edited on 2005-03-29 02:27:36
Post edited on 2005-06-13 04:03:17
Mon, Apr 4, 2005 at 6:38:30 PM | RE: Revit 8
MackAttack
Revit Building 8 is due to be release in US April 22. It is being called Building since they are working on a Structural version for the summer. Yes the version of 8 that is out is only a beta version for certain ppl who signed up for it early. I do know that it will support 3D DWF and be able to be linked to VIZ and 3DS Max (kind of like an XREF). I was not very familiar with the older versions of Revit so I am not sure what has been updated from the old versions.
Tue, Apr 12, 2005 at 8:53:32 AM | RE: Revit 8
skisouth
5 Stars: 3 Votes
Quoting Paulie - 2005-03-29 10:00:00
"I do know that it will ... be able to be linked to VIZ and 3DS Max (kind of like an XREF)."
No, Revit has no connection with Viz or Max. What will change will be that Viz 2006 and Max 7.5 will no longer require a special plugin to import a 3d dwg file from revit that will maintain material links.
Post edited on 2005-06-13 04:04:11
Wed, Apr 20, 2005 at 5:57:11 PM | RE: Revit 8
Ammar
i seeked every where for v8.0 but no output, i've heard that either in v8 nor 9. there' ll be something like the uilding systems, i hope so. -even in subscription i seeked-
Fri, May 13, 2005 at 3:29:57 PM | RE: Revit 8
MackAttack
Autodesk is due to release Revit Structure 1 this summer and is in the works for a version for the Mechanical side of things (thinking spring next year). I have not heard any rumors on weather or not this will include plumbing or electrical as Building Systems has but I am sure they are working on it for the HVAC side of things. Hope this helps clear things up.
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Page generation time: 1.4101
