Forums >> Revit Building >> Technical Support >> Can't open a Working Project#1
Fri, Apr 18, 2008 at 8:36:47 AM | Can't open a Working Project#1
tulsichoudary
I received this message when I attempted to open a revit file:
"Element 246673 became corrupt at some time before this session. To continue with this project, save a recover file. In the recovery file, this element will be deleted to fix the problem."
Then i received this mesage when i accepetd 2 this mesage ok:
An un recoverable error has occured. The programme will now be terminated. All of your data has been recovery saved, so there is no need to create recovery files.
How do I open my file to continue with previous?
I have followed all instructions what is saying but till now im not able to open my project file.  let me know what is the right way 2 open
Fri, Apr 18, 2008 at 8:45:54 AM | Can't open a Working Project#1
Did you look for the recovery file ?????  You can't open the old file!
Fri, Apr 18, 2008 at 9:56:57 AM | Can't open a Working Project#1
VNessa
Audit the file when opening it. I saw this on another thread. I had the same problem and this fixed it. When you open the file there is a check box that says "audit" check it and open the file.
Fri, Nov 2, 2007 at 12:37:27 PM
Project won't close
Mon, Mar 7, 2016 at 12:49:47 PM
Fri, Apr 18, 2008 at 7:21:32 AM
Revit Architecture can't open a large file
Thu, Feb 6, 2014 at 12:21:01 PM
Can't open REVIT
Thu, Sep 30, 2010 at 12:48:39 PM
Page generation time: 1.3190
