Forums >> Community >> Newbies >> Can't open a Working Project
Fri, Apr 18, 2008 at 7:16:23 AM | Can't open a Working Project
tulsichoudary
I received this message when I attempted to open a revit file:
"Element 246673 became corrupt at some time before this session. To continue with this project, save a recover file. In the recovery file, this element will be deleted to fix the problem."
Then i received this mesage when i accepetd 2 this mesage ok:
An un recoverable error has occured. The programme will now be terminated. All of your data has been recovery saved, so there is no need to create recovery files.
How do I open my file to continue with previous?
Fri, Apr 18, 2008 at 7:21:32 AM | Can't open a Working Project
Did you do everthing it told you to do?  If so, you should see a recovery file that you should now be able to open.
Fri, Nov 2, 2007 at 12:37:27 PM
Can't open a Working Project#1
Fri, Apr 18, 2008 at 9:56:57 AM
Project won't close
Mon, Mar 7, 2016 at 12:49:47 PM
Revit Architecture can't open a large file
Thu, Feb 6, 2014 at 12:21:01 PM
Can't open REVIT
Thu, Sep 30, 2010 at 12:48:39 PM
Page generation time: 0.8897
