Forums >> Revit Building >> Technical Support >> file getting too big, is there "xref" or something similar?
Thu, Apr 17, 2008 at 9:56:08 PM | file getting too big, is there "xref" or something similar?
sketchupmaster
my revit file is starting to get quite large, almost 125mbs at this point. i have already recieved the "memory low, revit may become unstable" message. i dont want the program to crash while im using it.
im wondering if there is a way to distribute the file into smaller pieces and therefore make the program run faster.
i guess this would be similar to auto cad's xref. where you can only access certain views with certain files, and then there is a ultimate "viewing" file where all the other files are combined.
 any help would be great, thanks to everybody in advance. please hurry, project due in a week.
Thu, Apr 17, 2008 at 11:48:04 PM | file getting too big, is there "xref" or something similar?
chiragpklg
4 Stars: 11 Votes
May be this tip would be helpful to u or not, but what i do is just divide the model in various files i.e. if I design ground floor in 1 file than the 1st floor is designed in other file, but imp. is to work with grids which will help u to attach all the file together properly.
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Fri, Apr 18, 2008 at 12:13:34 AM | file getting too big, is there "xref" or something similar?
sketchupmaster
'May be this tip would be helpful to u or not, but what i do is just divide the model in various files i.e. if I design ground floor in 1 file than the 1st floor is designed in other file, but imp. is to work with grids which will help u to attach all the file together properly."
could you explain the "imp."? nor am i familiar with "grids". how do these 2 things allow me to attach files?
 thanks again
Fri, Apr 18, 2008 at 12:19:41 AM | file getting too big, is there "xref" or something similar?
sketchupmaster
 thanks again
"Xref" in Revit
Sun, Mar 24, 2019 at 7:52:43 AM
"XREF" Families or other possibilities?
Fri, Apr 4, 2014 at 1:47:41 AM
Linked Cad File does not show Cad Xref's
Fri, Sep 10, 2010 at 10:13:50 AM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
"File not saved"
Mon, Nov 26, 2007 at 5:41:46 PM
Page generation time: 1.7133
