Forums >> Revit Building >> Technical Support >> KEY NOTE
Wed, Mar 23, 2005 at 5:06:01 PM | KEY NOTE
ARCHCOLL
When I copy a keynote and keep the number the same it shows up twice in the keynote schedule. Is there anyway to have it list the keynote only once in the schedule even if the key note symbol is used in more than one place? Is there a way to filter out the repeat entries? Thanks in advance Todd
Wed, Mar 23, 2005 at 5:18:48 PM | RE: KEY NOTE
RobGoetze
Edit the schedule properties: On the sorting tab, at the bottom right, is a checkbox for "Itemize every instance". Turn it off if you don't want multiple listings of the same keynote numbers.
Thu, Mar 24, 2005 at 9:13:33 AM | RE: KEY NOTE
ARCHCOLL
Thanks Rob I knew it was going to be some simple solution. I should of looked harder, thanks again for the responce.
Key Notes Across Divisions.
Thu, Jan 27, 2011 at 10:07:01 AM
KEY NOTE ABBREVIATION
Thu, Jun 2, 2005 at 6:07:46 PM
key note and schedule font
Tue, Oct 26, 2010 at 11:42:31 AM
Revit 2015 - Filter Note Block Keynotes by Those Visible on a Sheet
Sun, Mar 4, 2018 at 2:08:58 PM
keyed note question. (thanks for all of the help, by the way)
Thu, Feb 14, 2008 at 10:15:00 AM
Page generation time: 0.5351
