Forums >> Revit Structure >> Technical Support >> How to find the missing void object in family
Thu, Apr 17, 2008 at 10:30:13 AM | How to find the missing void object in family
architurk
architurk Avatar
3.5 Stars: 3 Votes
Hi all
I have put a void sweep in a family (together with some solid objects) and multiple cut some elements outside the family. Now i wanna make some changes to family but since i cannot recall void object inside the family, i cannot apply "uncut" on the objects, so it keeps giving error messages.
I know that when you cut sth the void always appear when you move cursor over the cutting surface, but not this time. I tried to do it in and out the editing mode of the in-place family, but didnt work!?!. When i try to erase the cut elements (outside the family) the whole family disappears.
thx
ps: i use ra 2008
Edited on: Thu, Apr 17, 2008 at 10:34:03 AM
Mon, Apr 21, 2008 at 12:54:48 PM | How to find the missing void object in family
fraz
hi,
how about isolating the family, then select all by crossing window. and then use filter selection - does the void sweep finally appear in the selection checkboxes?
Tue, Apr 22, 2008 at 1:45:14 AM | How to find the missing void object in family
architurk
architurk Avatar
3.5 Stars: 3 Votes
Hmm good idea, thx. Should give a try (i deleted and redone everything at that problematic point)
Wed, Apr 23, 2008 at 12:09:08 AM | How to find the missing void object in family
baek
Hi,
other option: if it gives you warnings / error messages with the void sweep, you can look up it's elememt ID (in tools - review warnings) and in Family editing mode you go to tools - element IDs - select by ID, enter the ID of the void and edit or delete or whatever you like to do with it now, as it is selected!!
I do loads with in place void families and find this works best!
k
Nested Void Problems on Shared Families (doesnt cut nested family if its shared)
Tue, May 10, 2016 at 8:39:49 AM
Face-Based Family for Void Form?
Wed, May 18, 2011 at 10:19:38 AM
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
Make void extrusion permanent
Wed, Feb 9, 2022 at 6:46:57 PM
void in family is yellow
Mon, Mar 12, 2018 at 12:22:43 PM
Page generation time: 1.7804
