Forums >> Revit Building >> Technical Support >> OWSJ Family
Wed, Mar 23, 2005 at 4:33:30 PM | OWSJ Family
kfpopeye
I'm trying to create an OWSJ family. I'm having some problems making the webbing parametric. I can create a round sweep at a 45 degree angle between the chords but I can't figure out how to lock the sweeps to the chords so they grow when the joist depth is increased. I downloaded the wood and rod truss family from this site but I can't figure out how the author did it.
Wed, Mar 23, 2005 at 9:17:25 PM | RE: OWSJ Family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You need to align the end points of the sweep path to the chords (best if assigned using reference planes). If you are still have trouble, post the family and i'll try to help you further.
Thu, Mar 24, 2005 at 12:29:17 PM | RE: OWSJ Family
kfpopeye
Thanks, I got that part. I was tying to constrain the sweep to the reference lines. I didn't realize you could constrain the sweep path. BTW is there a website that has the "Rules of Constraints" or something like that. I noticed the sweep behaving kind of funny when I was playing with the constraints. I couldn't figure out why it was behaving a certain way.
Thu, Mar 24, 2005 at 5:04:38 PM | RE: OWSJ Family
kfpopeye
Nope wait. Forget what I said. When I opened my model again to continue working on it. The constraints were no longer functioning the same way. It would seem that it is currently impossible to make a parametric OWSJ with Revit at this time.
Shortening OWSJ's
Tue, Apr 17, 2007 at 4:11:00 PM
Sloping 5/14" metal deck roof to sit on sloping OWSJ structure
Wed, Dec 3, 2014 at 8:50:16 AM
Spray Insulation
Wed, May 23, 2007 at 5:31:57 PM
open web steel joist
Wed, Sep 26, 2012 at 1:59:51 PM
Joists Problem
Mon, Jan 21, 2008 at 3:09:21 PM
Page generation time: 0.8823
